ORIGINAL: sehlers
Taurus Flyer -
From your post I assume you are inferring that Ted White Stole the Design ,Renamed it , and took credit for it ??? Because a person named Marty Moad made an Airplane called El Toro - in the early 60's .......
Other than having a Spanish name with a Masculine Prefix ,there are little similarities in the airframe design . There are no numerical dimensions in your plans to compare specifically ,but suffice it to say the fuse moments are different ,the fuse is construction is different ,The horizontal span is different ,the Rudder design is different, the Wing Airfoils are different .I can go on .....
Furthermore , the Horizontal movement was made by Ted in his design for the reasons I gave ,not to look like or copy the El Toro .
From what I know about R/C Precision acrobatics , in 1962 were they even doing 4 and 8 point rolls ? Slow Rolls ?? Knife Edge ? I don't have a 1961 AMA rule book or FIA manual ,if there was such a thing ,so I don't know with out some research .
Again Ted moved the tail to correct a pitching condition his first design had ,as he told me . Again if he stole the Idea from Moad ,you should lay blame also to Joe Bridi for using the same design criteria in his Super Koas in 1973 ....
What you are saying is basically, if an airplane has Any design trait or look of Any previously flown aircraft it Must be a Copy ......
Wow, the FAI and Masters pattern flyers of today would have a litigation nightmare with that one !
I will Talk to Ted personally and report back here with the "Truth" about the El Toro vs El Gringo Debate !
Happy Holidays to all !!!
Sehlers (Steve),
Give no mind to Taurass Flyer, he enjoys polluting every thread that contains any bit of information he deems unsuitable. It's much like the (his) "RC World according to Cees". As many have done, simply block him because a case of Summers Eve istoo difficulttoapply over the Internet.
hook
