trying to keep it as close to the fullsize configuration as possible, and trying to keep it somewhat scale..it works out to be about 1/4 scale...once it's finished i'll scale it and figure the hp per tonne to see how it compares to 1:1...i should be close to 750hp/t
front shocks mounted and figured the spider web of bracing required that'll still leave room to get the pipes off, clear link arms and driveshaft and fit in a tone servo and linkage just in case plan A steering setup don't work ...took a while to figure so it wouldn't look goofy, few more bits to add and the front end will be super strong
i'll get the front finished tomorrow then just the top and back to do...had to order a bit more steel, hope to have it by weeks end so i can get it done, stripped down and painted...obr top ends arrived today so will throw those on when the motor comes out for final welding...
