RE: ALIGN VS TAROT?
Usually what happens with clones is that they typically use softer grades of aluminum or the tolerances may not be as tight. With clones, if you are going to hover and do basic flight, then you most likely won't notice a difference. If you are much more aggressive, then the defects will emerge.
