RE: MP Jet diesel troubles
These are what I use-mostly homemade-with the exception of the 'Valvespout' bottle on the right (the same as hfenn's Dr Diesel offering) Just squeezable polythene bottles from the local plastics store, to which I fit an axially drilled (a lathe helps-but you can do it by eye with a handrill) brass bolt and nut, a couple of fibre or nylon sealing washers and your choice of length and diameter of K&S brass tubing soldered into the drilled bolt. [I usually countersink the hole on the bolt head side so it acts as a lead in to the brass tubing.] The smallest one shown has a capacity of about an ounce (~30mls) the largest about 8 ounces or 250cc-and that covers all my fuelling needs. I use them for both diesel and glow re-fuelling.
ChrisM
'ffkiwi'
