RCU Forums - View Single Post - Eindecker EIII
Old 02-22-2013 | 03:39 PM
  #281
abufletcher's Avatar
abufletcher
Default RE: Eindecker EIII
ORIGINAL: CubCrafter
Under flight loads the elevator was not very responsive...
Bear in mind that if you have used a scale sized stab/elevator (which I believe was the plan) then the elevator response is simply not going to be like what you'd get on a BUSA-style model with its greatly enlarged stab/elevator. Also the elevator response will be even weaker since you don't have a leading edge dipping down as you would on a full-flying elevator. I'm still working out the balance on my 1/6 scale EIII with 100% scale outlines but it also seems to have fairly weak elevator response.
