RCU Forums - View Single Post - DRONE 29S
Thread: DRONE 29S
Old 02-22-2013 | 05:29 PM
AMB
Default RE: DRONE 29S
GOT IT TODAY very stiff on turning hit with some WD40 a rinse insidewith some davis abc fuel it came with a topflight 10 inch pitch not known stuck it on the bench about 10 flips and a very loud bark a few more flips with some davis fuel and ran for a few seconds loud sounded like an AK 47 it needs a needle valve assembly and a rear gasket between tank an crankcase, that I can make up I would guess any c/l needle assembly would work very very stiff crank and rod ok no slop in either would ne nice to do a real run will have to scout up a drone needle or replace the whole thing, its been sitting for about 60 years
one of the extra crankcases has an intact c/l fitting so if I can find a needle will be ok
