RE: Theoretical troubleshooting
<ul>[*]The servo's are new in the elev's., slightly used in the ailerons and rudder[*]I took the receiver out to open it up so the connections will be double checked in pre-flight[*]The Tx is 13 months old and has not been in for check up[*]Took the back off the Tx and everything look good in there, receiver too[*]Receiver antenna geometry is good[*]I don't know where the internal failsafe is set up, maybe you can show me at the field. I'll try to find it in the manual[*]I checked the system battery after every flight and I don't let it get under about 7.5 volts[*]I have all my failsafe's set to 0 exceet for a little right rudder[/list]Thanks Bill
Randy<br type="_moz" />
