RE: 1/5 scale cesna battery/electronics
The ignition voltage needs to be looked at....all of mine are regulated to 5v through a regulator. I use LiIon batts at 2600 mAh rating. For the system I'd use 2 batts of the same rating although you can get by using just 1 batt
