RCU Forums - View Single Post - GP .60 Reactor Bibe
Old 02-25-2013 | 09:10 AM
  #303
steinywi
Default RE: GP .60 Reactor Bibe
NO! you need to make is less touchy. You need to make it so there is less change in the first half of the stick movement to allow you to find the sweet spot. I set my throttle so it is slightly less that half rpm at half stick, then make the rest of the transition to and from this point smooth. Full stick is max rpm not a wide open carb. Hope this helps.
Steiny
