RE: Larger Revolver
As ahicks said, that is safe. The issue is that measuring where that is can be difficult. If you use the finger-wingtip method, the correct CG is about 5/8" aft of the LE at the tip of the wing. The plane will fly well with the CG aft as much as 1" from the LE.
