RE: Getting back after 3 years
I just heat up the throttle/carb with a heat gun to loosen it then start the engine and run it for a while. If it runs then your OK, if not then I soak it completely for a few days then open it up and clean it completely with alcohol and a rag. Just running it heats up the engine and loosens up the old castor oil gunk.
