RCU Forums - View Single Post - extending antenna when testing??
Old 09-17-2003 | 04:47 AM
flyerdarren's Avatar
flyerdarren
Default RE: extending antenna when testing??
You only need to extend your antenna when flying. If your just checking the servo direction/travel, you don't need to worry about it. In fact, when you range check on the ground, you leave your antenna down. Hope this helps.
