RE: Smoke system flow question.
Here is an update
After reviewing all the responses and contacting Sullivan I programed my transmitter / receiver to slave the channel that I have the smoke pump on the throttel channel. I tested the pump and it advances the flow when I advance the throttel and gives an even steady flow to the muffler. The end point adjustments helped me control the volume of fluid thru the pump and I was able to keep the engine running at peak rpm's
I cant thank you guys eough for your help I cant waite to fly it .
THANKS
