RCU Forums - View Single Post - Taigen Tiger Early Version, Upper Hull Removal?
Old 02-26-2013 | 10:47 PM
jarndice
From: Hemel Hempstead,Hertfordshire, UNITED KINGDOM
Default RE: Taigen Tiger Early Version, Upper Hull Removal?
Glen, When my Tiger arrived one of the clamps holding the pipes in place was broken, as I was planning to upgrade to all metal I included two metal clamps on the list, I made sure the holes for the clamps were a tight fit, I smeared the ends of the pipes with Vaseline then pushed the clamps in place (NO GLUE) now all I do is lift out the clamps pull the pipes clear, and I lift the outer pipes on the air cleaners clear, then using the quick release at the same time swing the inner pipes up and the jobs done.   shaun
