RE: OS FP/LA -.15 Carb
Need help with os 15 fp... I have acquired a used os 15 that is bleeding fuel as the rpm's increase. I pulled the carb and the o ring is not torn, but is flattenned out. Do I just need to get a new o ring, or could I have a different problem? Is there a seal on the crankshaft, do I need to pull the flywheel?
