RCU Forums - View Single Post - Racing Engine cutting out.
Old 09-17-2003 | 08:36 AM
Smokinjoe6450
Default RE: Racing Engine cutting out.
is an air leak actually somethinb that will make a car die when you hit the throttle but not effect it whatsoever when you are at idle?
yes, when at idle the pressure is not that great but when you "punch it" you are building a vaccum which will allow in more air which will chock your engine
