Thanks for the info Cowboy. I don't plan on running high rates anytime soon and I'm a bit afraid of the roll rate on this bird anyway.
I'll turn the expo down to around 40% and try it that way on low rates. I'll set high rates expo a bit higher in case I accidently hit the switch. I once lost a plane by accidently hitting the high rate aileron switch without having set the high rates at all. They were at 100% with no expo. Some things Ihave to learn the hard way.
By the way, I can relate to your signature block. Been there done that ....and still doing it.
RJ
