<u>
Pump start point adjust and runup</u>
This video shows how to set up a KStart conversion or to troubleshoot
any K start problems.. Wren 100 shown with Zicoy ecu
What is ahown here is what I did to get my 54TP to start successfully.. wasn't that hard to do!!!
I also converted a Wren 75 from propane to Kero Start, it went perfect the first time. It is the turbine that provides the push
for my FOXself launch glider
Basically a too low "pump start volts" = failed start, a too high setting may give some unwanted flames, but once it
it dialed in you get perfection. My 54 needed 3 small increases to get it right..
Note.. this is a Wren 100 with<u>
22</u> lbs thrust..in the same sized case as the original Wren 54 and SuperSport.. quite nice!!
http://www.youtube.com/watch?v=DqzpP7U9Joc
