RE: GTM 1/2 Scale Fokker Triplane
Doc they also have the D-7, same format.
Well I decided to re-inforce the tail area where the stab bolts down. Added a few triangle supports. Also started to get the servo's figured out. Location and how I will do it. Up forward as much as possible for the servo's weigh in at 1/2 a lb. a peice. I will run carbon fiber tubes all the way back to some bellcranks then cable out to the horns. These are Hitec 805 MG, @ 343 oz each, two on elevator one on rudder. I plan to put the batteries and reciever on the same location. Access will be thru the belly panel.
TK
