RE: The Weirdest Problem
BEC failure doesn't produce logical results, it makes crazy things happen usually. Its just an idea, it may not be the case. The only thing you haven't changed is the ESC, right? What's the most common non-catastrophic failure on an ESC? The internal BEC. Do the symptoms match? Well, sorta, I admit it's not very compelling, but its all I got based on the facts provided.
