<span style="font-size: small">COMPARISON OF THE DIFFERENT BRAND MOTORS MADE AT THE SUNRAY TECHNOLOGY FACTORY</span>
<u>
<span style="font-size: small">INDOOR-SIZE MOTORS</span></u>
<span style="font-size: small"> </span>(21mm and 28mm diameter)
(listed in order of weight, ascending Kv, and number of turns-descending), (LP =LiPolice)
(For Turnigy SK3: Stated "Can length" is 1 to 3mm longer than stator length; and can be used to identify stator length of each motor;
"2118" -size motor has 1705 stator; "2122" motor has 1709 stator; "2822" motor has 2205 stator )
<span style="font-size: medium">15g, 16g
</span>(these motors have a 1705 stator -i.e. stator is 17mm diam, 5mm length)
SunRay 1705-1825Kv 14T, 16g=LP-1705/14T-1825KV=Infinite A1705-1800, 14T=HYPERION Z1705-14T 1800 KV=Foxy C1705/14 1825 Kv</p>
Gens ACE Mars BL2118-2050KV, 16T, 16.5g(-with Kv 2050, would expect less turns than 16T ?)</p>
SunRay 1705-2275Kv 11T=Turnigy SK3 2118-2250kv, 11T=LP-1705/11T-2275KV =Infinite A1705-2250, 11T=HYPERION Z1705-11T 2250 KV
Hacker 15g, A10-15 S, Kv 2320, ?15T, 12pole, D21 L21=FURY SA-10-15S / 2320Kv, ?15T, 15g=~Turnigy SK3 2118-2250kv, 11T=~LP-1705/11T-2275KV =~Infinite A1705-2250, 11T=~HYPERION Z1705-11T 2250 KV</p>
Turnigy SK3 2118-2750kv, 9T</p>
Hacker 15g, A10-12 S, Kv 2900, ?12T, 12pole, D21 L21=Fury-SA-10 ?12S / 2900Kv, 12T</p>
Turnigy SK3 2118-3100kv, 8T
<span style="font-size: xx-small">(Note: These 15g, 16g motors are listed in order of Kv. However, in this small section, quoted number of turns does not completely correlate with Kv -as it does for ALL other motors listed, up to 60-size motors. -I suspect theHacker A10-15 Sis actually an 11T motor, and that the Hacker A10-12 S is probably more like an 8T or 9T motor ...)</span></p>
<span style="font-size: medium">20g
</span>(these motors have 1709 stator)
Hacker 20g, A10-13L, Kv 1200, 13T, 12pole, D21 L25</p>
Hacker 20g, A10-9L, Kv 1700, 9T, 12pole, D21 L25=FURY SA-10-9L-1700 Kv, 9T =~SunRay 1709-1580Kv 9T=~Turnigy SK3 2122-1570kv=~LP-1709/9T-1580KV=~Infinite A1709-1500, 9T=HYPERION Z1709-9T 1500 KV=Foxy C1709/09 1580 Kv=APACHE APM10-9T, Kv1700=Gens ACE Mars BL2122-1580KV, 9T
<span style="font-size: xx-small">(NOTE:Hacker A10-9 Lhas a quoted Kv 1700; However, other identical motors with the same 1709 stator and 9T, quote Kv 1500 (Hyperion); Kv 1580 (LiPolice LP); Kv 1580 (Gens Ace)
DriveCalc shows that for these small motors, the measured Kv may actually be about 100 different from the Kv quoted by the brander / retailer.
For instance, DriveCalc shows that the LiPolice Z1705-11T 2250 KV has a measured Kv of 2461 rpm /V -200 more than the quoted manuf Kv;
It seems highly likely that the <u>
actual</u> Kv for the Hacker / Fury A10-9 L is more like 1600;and also that Kv of the Infinite / Hyperion1709 9T will be more like 1600 -this will make the Kv's of all these motors very similar )
</span>
Turnigy SK3 - 2122-1800kv, 8T</p>
Hacker 20g, A10-7L, Kv 2200, 7T, 12pole, D21 L25=SunRay 1709-2180Kv 7T=Turnigy SK3 2122-2100kv, 7T=LP-1709/7T-2180KV=Infinite A1709-2100, 7T=HYPERION Z1709-7T 2100 KV=Nova-Line DT1709/07-2200, 7T =Fury-SA-10-7L-2200Kv, 7T</p>
<span style="font-size: medium">29g
</span>(these motors have 2205 stator)
Hacker 29g, A20-50 S EVO, Kv 1088, 50T, D28, L22=Turnigy SK3 2822-1090kv, 50T=Nova Line DT2205, 50T -1090
Hyperion HP-Z2205-46T, Kv 1200</p>
Turnigy SK3 2822-1275kv, 40T</p>
Nova Line DT2205/38-1340, 38T =Hyperion HP-Z2205-38T, Kv 1370
</p>
SunRay 2205-1600Kv 36T=LP-2205/36T-1600KV=Foxy C2205/36 1600 Kv =Infinite A2205-1560, 36T
Hacker 29g, A20-34S EVO, Kv 1500, 34T, D28, L22=Torque 34T/1520, 29g, Kv 1520 34T=FURY SA-20-34S/1500Kv, 34T =APACHE APS20-34T 1520 Kv =Viper VA20-34S 1500 Kv=Lipotech ST1525 1525 Kv =Gens ACE Mars BL2718-1600KV, 34T</p>
SunRay 2205-1800Kv 32T=LP-2205/32T-1800KV=Infinite A2205-1740, 32T</p>
Turnigy SK3 2822-1740kv, 30T
Source of these data:
SUNRAY TECH data from: Their own information, spreadsheets provided by the SunRay factory themselves
HACKER motor data from:
http://www.hacker-motor-shop.com/e-v...mp;c=3&p=3
Extreme Flight TORQUE data from:
http://www.extremeflightrc.com/html/torque.html
TURNIGY SK3 data from:
http://www.hobbyking.com/hobbyking/s...amp;sortlist=W
LIPOLICE (LP) data from:
http://www.der-schweighofer.at/en/gr...shless_engines
OK Hobby INFINITE motor data from:
http://www.okhobby.com/category.php?id_category=169
HYPERION Z SERIES data from:
http://www.aircraft-world.com/shopdi...que+outrunners and
http://www.b-p-p.com/home.php?cat=30...n=0&page=3
RCM-PELIKAN "FOXY" motor data from:
http://air.pelikandaniel.com/?sec=ca...mp;category=21 ;
http://www.puffinmodels.com/category.php?dept=281
APACHE motor data from:
http://www.anyrc.com/product_html/pr...;bc_number=101 and
http://www.slowflyer.ch/elektro-antr...ache/index.php
PILOTAGE NOVA LINE motor data from:
http://www.pilotage-rc.com.ua/catalogue/85_/85_20/ ;
http://www.pilotage-rc.ru/support/ma...ine_manual.pdf
LIPOTECH motor data from:
http://www.lipotech.net/store/index....x&cPath=19
VIPER VA motor data from:
http://foamyfactory.com/viper-motors.htm
GENS ACE motor data from:
http://www.gensace.com/epages/genspo...irplane_Series
MEGAPOWER TAURUS motor data from:
http://www.megapower-rc.com/index.php?cPath=12_35_131
O.S. motor data from:
http://www.osengines.com/motors/index.html
FUTABA motor data from:
http://www.rc.futaba.co.jp/motor/
SHULMAN AVIATION "FURY" motor data from:
http://shulmanaviation.com/index.php?cPath=176
SONIC ELECTRIC motor data from:
http://www.sonicelectric.com/Merchan...tegory_Code=EM
COMMON-SENSE-RC motor data from:
http://www.commonsenserc.com/page.php?page=ezmatch.html
PRECISION AEROBATICS THRUST motor data from:
http://www.precisionaerobatics.com/t...ors/index.html
BMI-Models Spitz motor data from:
http://www.bmi-models.com/index.php?...s_motor/4/1401</p>
