RE: Struggling with single rotor basics V2
Och Dave ouch("you hurt me shrek") said donkey to shrek. I see on yahoo seemingly a hughes blew a deer to safety.
Scotty That sound is resonance in the fuse tail between the support points. It was worse in the first build before the crash. It eased up greatly since I dropped the throttle curve away fron the 3D head speed(maybe higher speed accentuating the bent hub) Ahh now remebering I cut a piece at the top to allow the flybar to pass freely.. down wash may be howling dow that hole.. I hear the sound...thanks I'm gonna block it. I already have the piece that was to go there that I never put on. Also it would be unfortunate for a bent hub, the wholething is new... well except for the electronics....dampners, bearings, hub, output shaft etc and does still does not mean the hub ain't bent-sigh. I'll put on the 550 blades(500mm is on there now) and see what happens. But I really checked out this bird good..6 weeks to rebuild.
Scotty please tell Dave to go away with the 4 bladed head.
