RCU Forums - View Single Post - Flap Problem
Thread: Flap Problem
Old 03-01-2013 | 05:03 AM
RICKSTUBBZ's Avatar
RICKSTUBBZ
Default RE: Flap Problem
Jolly,
If you have some older servos, as in before surface mount technology. The servo travel can be reversed. I am not near my notes. But as I recall on the old servos - you reverse the two wires that go to the “pot” and the two wires that go to the motor. That is what I did for the flaps on my “Wild Stik”.
This goes back to the days before servo reversing switches. You once could buy “reversed” servos. Man that goes back a while. As in early 80's and bottom end radios.
Of course the easy way is a servo reverser in line with your Y harness. HobbyKing has them reasonably priced.
