Yes you are correct I hope that didn't confuse the OP. I use 2 batteries also with the ign battery hooked up through the RCXEL switch. Theywork great and have the advantage of killing your engine if your receiver loses signal, but be careful which switch you use on your transmitter, I saw a video where a guy hit his kill switch instead of his mix in a hover. Bad scene
