RE: Flap Problem
On the few Top Flite airplanes I've built,(p-51, At6), that have flaps, I haven't used any reversing harnesses. If you look at the servo mounting plates on their models, the slot for the output arms are not in the same location. This is because one servo is turned over so the output arm is moving in the same direction as the opposite servo.
