RCU Forums - View Single Post - Flap Problem
Thread: Flap Problem
Old 03-01-2013 | 05:48 PM
AERORICH73
Default RE: Flap Problem
Hi Fellows: Ok, this problem arrived at my door step when purchasing a F-22 Hanger 9 Raptor ARF. I elected to go with the reversing JR servo while using all Hitec else where. The expense was a waste. The JR did not rotate the same as the Hitec, and i failed to check this movement of both brands. So out came the JR, and in when another Hitec wired to a reversering "Y" connector. Problem solved. In my reading on forums, there has been some discussions about changing the wiring in a servo, and at times there is smoke. It has been mentioned on this forum to view the Hobbyking website for parts to solve the reversing. With a few dollars more, the flaps work just fine, and the model is considered air worthy after completing the build. Buy a couple of the reversing "Y"s, and be reading for the next flap job.
[email protected]
Rich
