How many channels are you planning on using in your radio? If you have the ability to plug the flap servos into separate outputs on the receiver you can then use the "P Mix" function in your TX and mix them together.
Oops...saw that somebody beat me to it
In my opinion, using a mixing function in the TX is easier than Y-harnesses as you can adjust the direction and throws of each servo separately.
