I use the SD-10G for gas airplanes in the 70" range and it sounds similar to what you are looking for. The SD-10G is very easy to program and I was able to do most of it without even using the manual. I do recall looking in the manual when I was adjusting the throttle curve, which turned out to be very easy as well.
ORIGINAL: Checklst
Thanks Guys.........that is the info I was looking for. I saw the User guide, Quick start up guide,and Aero setups .............the quick start up and User guide look straight forward enough...........much easier than what I am use to on the JR. I also liked the Aero guide for the detailed follow the instructions to set up some more complicated type setups......most beyond what I need.
Thanks this really helped.
