RE: BH Ryan Special 92
Ian, I've read all of your post, but I am using a DLE30, have a 4.8 volt and a 6volt battery under the
cockpit, as far back in the fuse as they will go and my balance is way off. I'm using 123mm balance
point and the plane falls off of the balancer on its nose. I am going to have to add at least 2lbs of
weight in the tail, or there is no way this plane is taking off. I'm just deciding on the best way to add
the weight and I like the lead shot method with expanding foam. Will let you know how it turns out.
I watched your video of your ryan on you toube. Any trouble with the wheels inside the wheel pants,
not much room for any play from side to side. Looks like they may be short lived. Aframe2
