<p class="MsoNormal"><span style="font-size: 9.5pt; line-height: 115%; font-family: Verdana, sans-serif; background-color: rgb(251, 252, 255); background-position: initial initial; background-repeat: initial initial;">I must confess to all those below, which I've copied from prior posts!!
</span></p><p class="MsoNormal"><span style="font-size: 9.5pt; line-height: 115%; font-family: Verdana, sans-serif; background-color: rgb(251, 252, 255); background-position: initial initial; background-repeat: initial initial;">
</span></p><p class="MsoNormal"><span style="font-size: 9.5pt; line-height: 115%; font-family: Verdana, sans-serif; background-color: rgb(251, 252, 255); background-position: initial initial; background-repeat: initial initial;">You are on a first namebasis with your UPS guy</span><o
></o
></p><p class="MsoNormal"><span style="font-size: 9.5pt; line-height: 115%; font-family: Verdana, sans-serif; background-color: rgb(251, 252, 255); background-position: initial initial; background-repeat: initial initial;">You buy balsa at thehobby store even though you have boxes and sheets of it laying around, but youbuy it just because you may need it.<span> </span><o
></o
></span></p><p class="MsoNormal"><span style="font-size: 9.5pt; line-height: 115%; font-family: Verdana, sans-serif; background-color: rgb(251, 252, 255); background-position: initial initial; background-repeat: initial initial;">..if your wife is madbecause she can't find the windex but you have 2 bottles in your flightbox and one on your bench because you are using it to form sheating on theleading edge.</span><span style="font-size: 9.5pt; line-height: 115%; font-family: Verdana, sans-serif;">
<span style="background:#FBFCFF">...you have three extra kit boxes in your shop,one full of balsa bits, one full of plywood and spruce bits, and one fullof 10 or more sets of old plans.<o
></o
></span></span></p><p class="MsoNormal"><span style="font-size: 9.5pt; line-height: 115%; font-family: Verdana, sans-serif; background-color: rgb(251, 252, 255); background-position: initial initial; background-repeat: initial initial;">If you have ruinedalmost every shirt you own with CA or Epoxy.....</span><span style="font-size: 9.5pt; line-height: 115%; font-family: Verdana, sans-serif;">
<span style="background:#FBFCFF">If you have more X-acto knives than pairs ofunderwear.....</span>
<span style="background:#FBFCFF">If you have multiple Dremel tools so you don'thave to change bits as often...<o
></o
></span></span></p><p class="MsoNormal"><span style="font-size: 9.5pt; line-height: 115%; font-family: Verdana, sans-serif; background-color: rgb(251, 252, 255); background-position: initial initial; background-repeat: initial initial;">You go though morepapertowel in your workshop than you do in the kitchen...</span><span style="font-size: 9.5pt; line-height: 115%; font-family: Verdana, sans-serif;">
<span style="background:#FBFCFF">You have used an actual "sock" to<span> </span></span></span>
<span style="font-size:9.5pt;line-height:115%;font-family:"Verdana","sans-serif";color:black;text-decoration:none;text-underline:none">cover</span><span><span style="font-size: 9.5pt; line-height: 115%; font-family: Verdana, sans-serif; background-color: rgb(251, 252, 255); background-position: initial initial; background-repeat: initial initial;"> </span><span style="font-size: 9.5pt; line-height: 115%; font-family: Verdana, sans-serif; background-color: rgb(251, 252, 255); background-position: initial initial; background-repeat: initial initial;">your iron at least once...<span> </span>(mineis still on the iron…)<o
></o
></span></span></p><p class="MsoNormal"><span style="font-size: 9.5pt; line-height: 115%; font-family: Verdana, sans-serif; background-color: rgb(251, 252, 255); background-position: initial initial; background-repeat: initial initial;">. if you cut yourselfwith an X-Acto blade, used CA to close the cut, and used kicker to speed it upso you could get back to building. </span><![if gte vml 1]><v:shapetype id="_x0000_t75" coordsize="21600,21600" o:spt="75" o
referrelative="t" path="m@4@5l@4@11@9@11@9@5xe" filled="f" stroked="f"> <v:stroke joinstyle="miter"/> <v:formulas> <v:f eqn="if lineDrawn pixelLineWidth 0"/> <v:f eqn="sum @0 1 0"/> <v:f eqn="sum 0 0 @1"/> <v:f eqn="prod @2 1 2"/> <v:f eqn="prod @3 21600 pixelWidth"/> <v:f eqn="prod @3 21600 pixelHeight"/> <v:f eqn="sum @0 0 1"/> <v:f eqn="prod @6 1 2"/> <v:f eqn="prod @7 21600 pixelWidth"/> <v:f eqn="sum @8 21600 0"/> <v:f eqn="prod @7 21600 pixelHeight"/> <v:f eqn="sum @10 21600 0"/> </v:formulas> <v
ath o:extrusionok="f" gradientshapeok="t" o:connecttype="rect"/> <o:lock v:ext="edit" aspectratio="t"/></v:shapetype><v:shape id="Picture_x0020_1" o:spid="_x0000_i1025" type="#_x0000_t75" alt="http://www.rcuniverse.com/forum/
js/fckeditor/editor/images/smiley/msn/biggrin.gif" style='width:11.25pt;height:11.25pt;visibility:vis ible;mso-wrap-style:square'> <v:imagedata src="file:///C:\Users\shawkins\AppData\Local\Temp\msohtmlclip1\ 01\clip_image001.gif" o:title="biggrin"/></v:shape><![endif]><![if !vml]>[img]file:///C:\Users\shawkins\AppData\Local\Temp\msohtmlclip1\ 01\clip_image001.gif[/img]<![endif]><span style="font-size: 9.5pt; line-height: 115%; font-family: Verdana, sans-serif; background-color: rgb(251, 252, 255); background-position: initial initial; background-repeat: initial initial;"><o
></o
></span></p><p style="margin-bottom: 0.0001pt;" class="MsoNormal"><span style="font-size: 9.5pt; font-family: Verdana, sans-serif;">... if you have ever waited til everyone's gone to bed to unpackyour vehicle with the stealth of a Mafia hit man. <o
></o
></span></p><p style="margin-bottom: 0.0001pt;" class="MsoNormal"><span style="font-size: 9.5pt; font-family: Verdana, sans-serif;"> </span><span style="background-color: rgb(251, 252, 255); font-family: Verdana, sans-serif; font-size: 9.5pt;">If you have a hard time throwing away ANY woodscraps , because you KNOW they will be perfect for the next little project.</span><span style="font-family: Verdana, sans-serif; font-size: 9.5pt;"> </span></p><p style="margin-bottom: 0.0001pt;" class="MsoNormal"><o
></o
></p>
