RE: Top-Flite 1/5th F4U Corsair ARF Group Build and modification thread
Chad that is great. Your example has given me some great ideas. I'm going to try placing the bulk heads directly into the wet fiber glass while into the mold. Once the fiber glass has harden and I can pull each half out of the mold I'll let each cure and then try to use the expanding foam to fill in between the bulk heads.
What do you think? Chad? Bob T and Bob H?
