<u><span style="font-size: small">COMPARISON OF DIFFERENT BRAND 60-SIZE MOTORS, MADE AT SUNRAY TECHNOLOGY FACTORY
</span></u>
<span style="font-size: medium">60 SIZE MOTORS </span>(59mm, 60mm diameter)
(listed in order of weight, ascending Kv and number of turns -descending), (LP =LiPolice)
NOTE: All Turnigy SK3 "63"-series motors -actually have diam of 60mm (-and not 63mm, as their name suggests ...).
(SK3 6364 and 6374 motors have a large radial bearing / fan assembly behind front static housing -stator appears to start ~15mm behind front of can )
(Hacker A60 M and A60 L motors have an identical bearing / fan assembly behind black front static housing -these are front mounted motors)
SK3 "6354"-size motor has 5025 stator; "6364" motor has 5035 stator (-it is 73mm long overall); "6374" motor probably has ~5045 stator (-it is 86mm long overall)</p>
<span style="font-size: medium">442g
</span>(these motors have 5020 stator)
SunRay 5020-225Kv 30T, 442g, D60 L56=LP-5020 /30T-225KV=Infinite A5020-215, 30T=Foxy C5020/30 225 Kv</p>
SunRay 5020-275Kv 26T=LP-5020 /26T-255KV=Infinite A5020-250, 26T=Foxy C5020/26 275 Kv</p>
APACHE APX51-22T, Kv300, 450g, D60 L43= Gens ACE Mars-BL5943-215KV, 22T,438g, D60 L43(-has 5020 stator)(-with Kv of 215, is30T?)
APACHE APX51-16T Kv 400, 16T, (450g), D 60 L43
APACHE APX51-14T Kv 480</p>
<span style="font-size: medium">480g
</span>Hacker 480g, A60-5XS V2 28-Pole, Kv 420, 5T, 28pole, D60 L52 (-will have stator 5020)</p>
Hacker 480g, A60-6XS V2 28-Pole, Kv 370, 6T, 28pole, D60 L52</p>
Hacker 480g, A60-7XS V2 28-Pole, Kv 320, 7T, 28pole, D60 L52</p>
<span style="font-size: medium">523g
</span>(These motors have 5025 stator)</p>
SunRay 5025-175kV 28T, 523g, D 60 L61=LP-5025 /28T-175KV=Infinite A5025-170, 28T</p>
SunRay 5025-195kV 24T, D60 L61=LP-5025 /24T-195KV=Infinite A5025-195, 24T=HYPERION Z5025 24T 200 KV, (570g), D 60 L 61=Foxy C5025/24 195 Kv=Pilotage Nova Line DT5025/24 - 195Kv (595g)</p>
SunRay 5025-230kV 22T=Turnigy SK3 6354-215kv, 22T (485g), 14 pole, 12 stator arms=LP-5025 /22T-230KV=Infinite A5025-225, 22T=HYPERION Z5025 22T 215 KV=Pilotage Nova Line DT5025/22 - 217Kv (595g)</p>
HYPERION Z5025 20T 235 KV, (570g), D 60 L 61=Turnigy SK3 6354-245kv, 20T, 485g <span style="font-size: xx-small">(-both motors have 5025 stator, same Kv and no. turns -but different quoted weights; Stated weight may not be correct )</span></p>
Turnigy SK3 6354-260kv; 485g; 18T (-has 5025 stator)</p>
<span style="font-size: medium">590g
</span>(These motors have 5030 stator)</p>
Hacker 590g, A60-24S V2 28pole, Kv 195, 24T, 28pole, D60 L61 =HYPERION Z5025 24T 200 KV</p>
Hacker 590g, A60-22S V2 28pole, Kv 217, 22T, 28pole, D60 L61=HYPERION Z5025 22T 215 KV =~SunRay 5030-185kV 22T, 591g, D 60 L66 =LP-5030 /22T-185KV=Infinite A5030-190, 22T</p>
Hacker 590g, A60-20S V2 28pole, Kv 245, 20T, 28pole, D60 L61=HYPERION Z5025 20T 235 KV=~SunRay 5030-235kV 20T, 591g=LP-5030 /20T-235KV=Infinite A5030-235, 20T
<span style="font-size: small">(TheHacker A60- S motors are available in 20, 22, 24T;TheHYPERION Z5025are also available in20, 22, 24T;
They are
IDENTICAL )
</span>
SunRay 5030-265kV 18T, 591g=LP-5030 /18T-265KV=Infinite A5030-260, 18T</p>
Gens ACE -Mars 5953-225KV, 590g, 16T, D 60 (-Gens Ace specs quote5030 stator, 14 pole) (-with low Kv of 225, might be 20T?)</p>
(older Hacker A60-...S "V1" motors, were 14 pole -V2 motors are 28 pole )</p>
Note: Re: Hacker A60-22S
"This motor has now been replaced with the Hacker A60-7S V2 28-Pole, it is the same motor, but it is rear mounted. Now there is no need to use the motor cage for sebart kits" -
http://www.dumfries-model-flying.com...-22s-kv-217-v2</p>
<span style="font-size: medium">595g
</span>(These motors also have 5030 stator)
(Hacker A60-24S V2, replaced by A60-8S V2; Hacker A60-22S V2, replaced by A60-7S V2; Hacker A60-20S V2, replaced by A60-5S V2)</p>
Hacker 595g, A60-8S V2 28-Pole, Kv 188, 8T, 28pole, D60 L62=~SunRay 5030-185kV 22T, 591g, D 60 L66 =LP-5030 /22T-185KV=Infinite A5030-190, 22T</p>
Hacker 595g, A60-7S V2 28-Pole, Kv 215, 7T, 28pole, D60 L62 =~SunRay 5030-235kV 20T, 591g=LP-5030 /20T-235KV=Infinite A5030-235, 20T</p>
Hacker 595g, A60-5S V2 28-Pole, Kv 295, 5T, 28pole, D60 L66 =~SunRay 5030-265kV 18T, 591g=LP-5030 /18T-265KV=Infinite A5030-260, 18T
</p>
<span style="font-size: medium">697g
</span>(For SK3 6364, Can length is 52mm; due to bearing / fan assembly, stator starts ~15mm behind front of can -indicating 5035 stator)
Turnigy SK3 6364-190kv; 697g; 18T; D 60 L73, 14 pole, 12 stator arms</p>
Turnigy SK3 6364-213kv; 697g; 16T; D 60 L73</p>
Turnigy SK3 6364-245kv; 697g; 14T; D 60 L73</p>
<span style="font-size: medium">760g
</span>(these motors have 5035 stator)
Hacker 760g, A60-20 M, Kv 170, 20T, 14pole, D60 L74=Hyperion Z5035-20, 20T, 170Kv, 730g, D 60 L 71</p>
Hacker 760g, A60-18 M, Kv 190, 18T, 14pole, D60 L74=Hyperion Z5035-18, 18T, 190Kv, 730g, D 60 L 71=~Turnigy SK3 6364-190kv, 18T, (697g); D 60 L73</p>
Hacker 760g, A60-16 M, Kv 215, 16T, 14pole, D60 L74=~Turnigy SK3 6364-213kv, 16T, (697g); D 60 L73
</p>
<span style="font-size: medium">823g
SunRay 5035-165kV 22T, 823g, D 60, L 83=LP-5035 /22T-165KV=Infinite A5035-160, 22T</p>
SunRay 5035-195kV 18T, 823g=LP-5035 /18T-195KV=Infinite A5035-190, 823g, 18T, D60 L83=~HYPERION Z5035 18T 190 KV
</p>
<span style="font-size: medium">910g
</span>(These motors have 5045 stator)
(For SK3 6374: Can length is 62mm; due to bearing / fan assembly, stator starts ~15mm behind front of can -indicating 5045 stator)
Hacker 910g, A60-18 L, Kv 149, 18T, 14pole, D60 L84 =Hyperion Z5045-18, 18T, 149Kv, 890g, D60 L81=~Turnigy SK3 6374-149kv, 18T (840g) D60, L86</p>
Hacker 910g, A60-16 L, Kv 168, 16T, 14pole, D60 L84=Hyperion Z5045-16, 16T, 168Kv, 890g=~Turnigy SK3 6374-168kv, 16T (840g)</p>
Hacker 910g, A60-14 L, Kv 192, 14T, 14pole, D60 L84=~Turnigy SK3 6374-192kv, 14T (840g)</p>
</p>
<span style="font-size: medium">995g
</span>SunRay 5045-155Kv 18T, 995g, D60 L 93=LP-5045 /18T-155KV =Infinite A5045-150, 18T</p>
SunRay 5045-185Kv 14T=LP-5045 /14T-185KV=Infinite A5045-180, 14T
</p>
