ORIGINAL: bigheaded5
Are all 2.4Ghz Tx compatable with any 2.4Ghz Tx if the TYPE is the same....example....DSSS with another DSSS or a FHSS with another FHSS?
Can I switch back and forth between two Tx from day to day OR do they learn each other and stay specissic to each other?
Not unless they are the same manufacture. If they are you will need to rebind each time you switch.
