RCU Forums - View Single Post - Official HPI MT2 Thread
Old 03-06-2013 | 01:44 PM
  #21623
SyCo_VeNoM's Avatar
SyCo_VeNoM
Default RE: Official HPI MT2 Thread
ORIGINAL: Arachna
The RS4 clutch shoes was sort of a stopgap, although it seems to be working well atm. Shortly I intend to go with Mashers, 13t clutch bell and will then probably go with a Savage flywheel and clutch setup.
99% sure that won't fit pretty sure the crank shafts are different sizes.
unless you will throw in a .21-.28 engine then it would work(that requires a bit of modding from what I seen)
BTW nice Punisher skull on the HPI JSDF body
if you go mashers you will need to trim the front wheel well a quite a bit. I ran mashers on mine with the HPI MT1 chevy truck body, and had to take a quite a bit off. I ran mine with the 15t spur on a .15 engine, not sure how it would work on the .18
