RCU Forums - View Single Post - Futaba 3010 Servos--How much play is too much?
Old 09-17-2003 | 03:34 PM
Bax
Default RE: Futaba 3010 Servos--How much play is too much?
Any 'play' is a bad thing, but there has to be a little for the geartrain to work properly. It does sound like your servos' gears are a bit loose. You might try replacing the gears on one of the servos to see if it tightens up a bit.
