RCU Forums - View Single Post - Write-up: Carburetor screw adjustment guides
Old 03-07-2013 | 08:41 AM
grosbeak's Avatar
grosbeak
Default RE: Write-up: Carburetor screw adjustment guides
Next, I wanted to see where the tubes come to rest on the cowl when it's put on. In this case, just above the access holes.
I cut the tops off the backs of the grommets and epoxied them in place. And yes, it is a little too much epoxy - thanks for noticing!
Now when the cowl is put on I just need a hook to pop the tubes into the grommets.
There they go!
