RCU Forums - View Single Post - THROTTLE RETURN SPRING
Old 09-17-2003 | 04:59 PM
bluefluffybunny1
Default RE: THROTTLE RETURN SPRING
The problem is that fail safes only work if there is power so if you lose a battery connection or yuor switch fails then you car crashes into a stream and the engine gets stuck at full throttle and destroys itself (it will never fail at idle...).
I want to make a neat and reliable throttle return for my MBX5 and don't want to make a bodge job!
Any ideas where to mount the spring, The fuel tank and engine mounts are at an angle so require a stronger spring to return the throttle which in turn means that the load on the servo is increased.
Has anyone found a good method?
