RCU Forums - View Single Post - Ignition cut off
Old 03-08-2013 | 06:48 AM
rrritchey
Default RE: Ignition cut off
Hi,
The new 2.4 Futaba radios set failsafe just like the PCM radios in the transmitter except for
some of the low channel receivers which only failsafe the throttle but they are typically
park flyer type receivers.
ORIGINAL: kckrcer
Ah there's the rub. I forgot to put in the other part of my situation. I am flying with a Fut. 9-C Super with a add on 2.4 module. In order for 2.4 to work you have to use PPM mode. To have fail safe you must be in PCM mode. So it would appear I can't have ignition cut off at loss of signal with this rig. Do the new radios now have failsafe on 2.4?
Thanks for replying.
KCKRCER
