How do you remove the Stators on a C05 Micro
Hello everyone, I purchase this C05 motor from Hobby Partz for a Guillows Lancer I'm building. Everything was fine until I removed the motor to finish covering the front of the plane, when I put the motor back onto the plane I got that nice awful "jittering" from the motor and it wouldn't run. My experience told me that Ihad a broken lead/wire. Sure enough I pulled the magnet housing off the motor and found a lead broken. I can't seem to pull the stator from the back of the motor housing, and I'm not sure if its press fitted on or glued on. It appears that it may have been pressed on then then glued but I'm not sure.
If any of you have any experience getting the stators off an "Outrunner" motor I would greatly appreciate your thoughts.
