Servo Extensions
Hope this is the correct location to ask this question. I have Futaba servos installed in a Funtana 125. The aliron (2), the elevator(2), and rudder(1) servos all require extension cables. I have been told that there is considerable voltage loss through the male/female connectors. Can I eliminate the connectors and solder the extension to the servo leads? Is there a special solder that should be used? Should the solder connections be off set?
