RE: How do you remove the Stators on a C05 Micro
I tried heating it this morning with a soldering gun with no avail. However placing it in the oven may do the trick. The idea is to JUST solder the wire that broke, then placing a small peice of heat schrink tubing on the solder joint. Worse case scenario, if I get it apart I could try my hand at re-winding the stator. However at my age, that might be a BIG challenge. I REALLY think the small RC stuff is cool, but sometimes a pain to build or work on.
Those are my thought for the repair, but I just may have to purchase another motor if I can find one.
David
