ORIGINAL: 4*60
Solder all you like. Offset not needed if shrink tube used, but it's OK for insurance. Solder for electronics rosin core.
Or just use 6.6v life packs.<br type=''_moz'' />
Thanks. I understand about the soldering and will give it a go. However, these are Futaba 3305 servos that call for NiCAD batteries only. Either 4.8 or 6.0 volts. Have been told that using the life pack will harm the servos. Your thoughts on this issue?
