RCU Forums - View Single Post - Linking Receiver?
Old 03-10-2013 | 07:11 AM
ggate
Default RE: Linking Receiver?
I am not sure if this would be correct with your set-up. I have a Flysky 2.4GHZ with 2 different receivers. When i bind to the reciever for each model i am done,just select which plane you want to fly. Just make sure you save the setting for each plane if the servos are setup different under the model name.
