RCU Forums - View Single Post - J-3 cub Identifly.
Old 03-10-2013 | 08:07 PM
blvdbuzzard
Default RE: J-3 cub Identifly.
Well the eflite 25, with a 4s battery should fly a 4 pound (64 ounce) plane with ease. It should be putting out some where around 5.25 pounds of thrust. So it is over powered for the Cud and the small 2 pound plane.
I use this calc tool.
http://www.s4a.ch/eflight/motorcalc_e.htm
This little motor on a 3s battery turning a 10X6 prop will fly the 36 ounce plane
http://www.e-fliterc.com/Products/De...rodID=EFLM1505
Or this one
http://www.hobbypartz.com/75m21-opti...10-1020kv.html
I too was going way over kill on the motor battery size. I have learned that sometimes smaller lighter is more power.
The 3s 4000 is a little big for the Cub butt will work. Just more weight to fly around. You will get real long flights with it.
Buzz.
