RE: P120 Temperature probe failure (error)
The probe is like a metal tube with two VERY fine little wires running through it. On the end where it plugs into the PCB at the front of the turbine is where they break. You could possibly re solder the broken wire but they are VERY small and fragile. The good news is that a new Temp Probe is not all that expensive. Jetcat can pre-bend it for your model motor so installation is not too hard. Just be very careful on the plug end not to put too much mechanical stress on it or it could break the replacement also.
Happy Flying,
Steve<br type="_moz" />
