Need help identifying an older arf
Someone at work wants me to fix up this old arf back to flying condition again. It's not in to bad of shape, I just don't know who made it. The fuselage is made out of a hard plastic material. It looks like it Was a two piece body that was glued together at the center seam. It has flashing around the center seam where it is glued together. The wing is made out of foam with some covering over top of it. It has an Os 40 engine on it. Other than that I don't know much about it.
The wing I think is in ok shape but it does feel like there may be a weak point or fracture in one side of the wing. Would you trust flying it as or repair it first. I have been thinking about shoving an arrow shaft down the center of the foam to make sure it's strong enough.
