ORIGINAL: Prekin
ORIGINAL: Sharpeye22
A 1/5th scale is way to big. I have a couple of Dragon pilots. I will do surgery on the one I will use to lighten it up a lot. (Replace the body with foam and only use the head, hands, boots, and cloths/gear). At 1/6th it is still just slightly to long but when I craft the body I will fix that.
Hi Sharpeye,
the Dragons pilots look very nice. Do you know what is the weight and height (1/5 and 1/6 scale) of these pilots? I thinking about one Dragon pilot for the ESM La-7.
If you go on ebay via this link
http://www.ebay.ca/itm/1-6TH-SCALE-W...item2a19a447f1 you will see a seller who makes insignia for 1/6 scale pilots. He had Soviet airforce insignia in the past. Send him a message and he will get them for you. I have a set of Soviet insignia as well. You can get the 1/6 Soviet uniforms of ebay quite reasonably. Most late war Soviet pilots wore the same uniform as the infantry with just different collar or epaulet insignia. Tero T in Toronto
