RE: Stall Question
Adding a bit of washout would not be difficult. You would need to have an incedence meter and a heat source.
Oddly enough, I did go back and do this to my Tecate.
Twist the wing a bit at the tip, heat the top covering and measure to see what you have got. It is then important to duplicate the same amout on the other wing. 2-3 degrees works well.
Sorry about being anal about the laminar thing. We are talking aerodynamics so it helps the rest of us to understand someone elses views when we use the correct terminology.
Schmleff
