One more question before first flight
If you read my first post you can see that I bought a Cessna 182 class 500 with 51" wing span. The nose cowl was split from front to back when I unboxed it. When I looked at the motor and shaft from the front it looked like the motor shaft was way off center of the cowl but I thought it looked that way because the cowl was busted and sort of warped. I got the cowl off and the motor is mounted crooked to one side. If your are facing the planes front the motor is slanted to the left. Is this right or just another flaw in this palne???</p>
