RCU Forums - View Single Post - Jato 3.3 shock setup help!
Old 03-13-2013 | 09:29 AM
nitroexpress's Avatar
nitroexpress
Default RE: Jato 3.3 shock setup help!
ORIGINAL: Clay2010
<span>Hi I was wondering if someone could tell me a good setup for jato 3.3 shocks setup.
ill be driving it on pavement only. Just trying to get a but more steering control and actually seeing all 4 wheels stay on the ground when taking turns very soft. Seems like the front stays down but, the back left or right comes up depending on which way I'm turning.
Any suggestions would be much appreciated
thanks clay.</span>
If it's pavement only, then use stiff settings. If you don't have sway bars, use stiff ones.
http://www.amainhobbies.com/product_...FW2oPAodQUMAmQ
Springs - use stiffest ones and limit droop
http://traxxas.com/pitpass/howto/new...pension-Tuning
40W oil should be in the ballpark.
